Mercury Villager, 1995. Yesterday, I left work and at a stoplight white vapor was pouring out from under the hood. I stopped, opened the hood and white vapor billows out. Temp gauge was normal. I turned off the heater, and drove home, watching temp gauge. It stayed normal. After I had gone about 4 miles, I pulled over and opened the hood. No vapor. I checked the coolant recovery tank and it was empty. Drove home and today drove the five miles to work with no vapor. Temp gauge did go up to higher in the normal range but the fan kicked on and the temp went down. No overheating has occurred.
Today I put some antifreeze (a quart, maybe) in the recovery tank, and the vapor returned. Turned off the heater and the vapor went away. Temp gauge goes up a little but fan brings it back down.
This is puzzling. I'm going to replace the radiator cap because it's cheap but I doubt that is the issue. No coolant leak detected. No coolant on the ground, no hissing from the engine compartment.
Any ideas on what may be causing this? Thanks.
