Purchasing a home built in 1968 in Savannah GA. Crawl space is only about 2' off ground. Dirt but inspector advised very dry but recommended a moisture barrier.
Couple of questions.
I see many different materials such as silverback vs poly? What should be used?
How should it be installed? I get the overlap, but does it need to go up the foundation walls? If so how far?
Do I need to any ground uncovered. It has foundation vents to code supposed, do I need to close them.
Help on what I need to do to get the crawl space improved to the right condition for the long term.
