Hi has anyone dealt with a crawlspace like this? The ground is very uneven, covered with boulders and a lot of support columns. House was built in 1850.
The ground is very damp as you can see. I've put a 70 pint dehumidifier since this photo was taken and it really helps keeping the humidity around 70%. I'd like to add a vapor barrier on the ground to further reduce moisture intrusion. I'd say there's about 18" of clearance to crawl around in there.
Any ideas? Should I just cut out an oversized sheet of poly and lay it on top of these rocks? I guess if I measure carefully I can pre cut the holes for the chimney and support columns, then I'd only have to tape the slits afterwards. Seems like whatever I do is going to be a pain in the butt.
