Yet another vapor barrier question
My poured wall basement has a sprayed on waterproofing membrane, a dimpled drainage mat, plus another drainage board on the exterior. I'm planning to start finishing the basement now, and I'm not sure what the requirements are for a vapor barrier. I called our local inspector, and he said in the central Alabama area, a vapor barrier is not required. However, after reading as much as I can online, there seems to be several different views on this, albeit most seem to be in relation to basements further north.
The room in question will be a soundproofed home theater. The framed wall is approximately 1" from the foundation, and I would like to use fiberglass insulation for sound deadening. drywall will be suspended from isolation clips and hat channel, so there will be an additional 1-1/2" gap between the insulation and the drywall.
I appreciate any feedback!
