Where is the home/shed going to be located?
What do the shed instruction say? A vapor barrier across the floor would be a good thing to keep any moisture down and under the plastic but a vented space (much like a crawlspace) would be preferred.
What is your insulation schedule for the floor?
Rigid foam across the bottom of the framing would be a good thing if you are going to heat and use this thing.
