Hi,
I am trying to get my slanted wood floors leveled (about 5.5 " differential) including a vapor barrier, to prevent odors, fumes and hot air from coming up through the floor.
Planning to have the contractor remove the top flooring up to the sub floor, then building the floor to level with sleepers, adding plywood to create a new, level subfloor, then a cross-laminated virgin polyethylene sheet, sealed at the sides with silicone gasket and 1/2 x 2 wood, screwed or nailed into the sheet rock of the walls.
Does anyone have experience with this? The flooring guy seems to be uncomfortable with not being able to nail through the plastic and how to properly attach the top floor. Assuming there should be rosin paper or felt or something of the like between the PE and the top floor. Can the PE be glued to the wood above or below, and if yes, with which product?
Anyone with experience and suggestions? Thanks
