1 - 13 of 13 Posts
Where does this light usually go in the system? Is it installed right after the air handler in the main trunk to kill any bacteria right after the air is conditioned?
I would assume the selling point is that the moisture in the condensation can cause some mold/mildew in the air handler, which is probably very common and expected.
Above the coil, so it can prevent bacteria from growing.
+1 what Beenthere said :thumbsup:
UV Lights are one of my best selling items, I ship several each week, but I also have some very personal experience with them as well.
Four out of the past five years, I have suffered extreme bronchial issues. The last two years, it manifested into full blown pneumonia in my left lung. After the last bout, I decided to do something about it. This hits me each year about mid July and had me down for over six weeks each time.
I put a BlueTube UV light above my A-Coil in my air handler and also added a 5" Trion Air Bear to my system. Last year I made it through without a problem, and so far this year all is good (knocking on wood).
When I installed the light, there was significant mold growing on the coil and insulation of the AHU. When I changed my bulb last year, it was all nice and clean:thumbup::thumbup:
If you are planning in installing a 24 volt, just make sure that you are confident that you can locate the two 24V wires. If not, just order a 120V and wire to your home power.
Also, if you have a variable speed blower drive in your air handler or furnace, you should add an additional 24 volt transformer (usually under $12). If not you are open to power spikes from from your blower system that will prematurely roast your power supply or bulb.
Good Luck,
Good Luck,
Thanks for passing along your experience.
I'm not planning on doing anything yet, but this thought about about moisture in the coils and bacteria/mold seemed like a no brainer possibility.
I'm surprised HVAC companies don't advertise more about offering to address/clean this as part of their maintenance.
How hard was it to mount the blue tube? Slab, A-coil, or perpendicular?
http://www.bluetubeuv.com/Blue-Tube_specs-web.pdf
It took me longer to find my tools than it did to mount. Maybe 30 minutes total. Here is a simple paragraph from my site that explained my install process. I would post the link, but can't as it would be self promotion.
"First I cut the power to my system. I removed the access panel of my air handler and located the 24 volt transformer. Next I wired the two power wires from the Blue-Tube power pack to the 24 Volt transformer. I decided on the best location for the light and drilled a 7/8” hole into the case of my evaporator coil. I then inserted the light into the hole, until the magnet set the lamp into place. Next, I attached the Blue-Tube power pack to the side of my air handler, placed the door back on and turned the power back on to the system……TaDa! That was it. Actually, there was one more little step. I drilled a small hole into the front of my coil and inserted the indicator lens. Ok, that was all there was to it. Maybe 30 minutes at most."
If you have an A-Coil, either position (above or below) is acceptable, but I prefer above the "A". If a Slab I would put it on the return side. With UV lights, you do need to watch that the light does not shine on coated wires, as it will deteriorate the coating. Also, some older drain pans can also be effected by UV as well. If you do have these exposures, simply covering these areas with silver tape will take care of the issue.
Good Luck
Discussion Starter · #6 ·
Good Luck
How much do they sell for and are there install instructions online (esp for the wiring)?
Coil Mounted Lamps:
1 Year lamps run between $159 - $249 depending on options and power requirement.
2 Year Lamps are $259 - $289 depending on power options.
Install instructions are included with each light and we forward the same PDF in advance (but after the sale) so that HO can get prepared.
Discussion Starter · #10 ·
Handyman88,
I sent you a PM.
Thanks, I'll look into it.
I did some exploring today and did find the 24V transformer.
What do you mean by "coated wires" and "older pans?" do you mean any electrical wiring inside the air handler that the UV light can reach? I did not see any wiring located near the A coil. It seems to me that I have a delrin/nylon white pan.
When researching UV Lamps you might also consider the cost of replacement bulbs and if this includes a ballast.
There is a large range in the price of replacement bulbs.
The Honeywell RUVLAMP1/C UV Lamp runs ~ $114.00 on Amazon and replacement bulbs are $26.
I decided on the best location for the light and drilled a 7/8” hole into the case of my evaporator coil. Good Luck[/QUOTE said:
I realize that this is a 6 yr old thread, but I had to ask. Is what he did OK? I would think it not good to go into the side of the evaporator case.
Shouldn't it go into the plenum about the coil?
1 - 13 of 13 Posts
