Hi
I'm based in Johannesburg, South Africa. We live in the original Joburg farmhouse, which is a rambling structure with 600mm thick outer walls and 5m high ceilings. Above the celings is a cavernous attic (650m2) in which a person can stand up. The attic is topped off with a dark green corrugated iron roof.
In summer the attic gets uncomfortably hot and in winter it gets fairly warm - winter days in Joburg average around 20 to 22 degrees Celsius with most days being full sunshine. The attic temperature in winter gets significantly warmer than 22 degrees C.
A few rooms on the western side of the house get very cold in winter and I was thinking of cutting a hole (say 20cm diameter) into the ceiling of each of the cold rooms and installing bi-directional fans, which can blow warm air from the attic into the rooms in winter and warm air from the rooms, which also get pretty warm in summer, into the attic in summer.
Has anyone tried this before?
Given that the ceilings are 5m high, might this create a problem to heat the lower level of the rooms?
Am I missing something?
Any advice?
Any advice?
