1 - 20 of 34 Posts
I watched a YouTube instructional video to use painters tape when caulking to get a perfect straight line. I've always just used my finger with water of soapy water to pull a nice straight line.
Anyone used this method and when do you remove the tape when the caulk is dry or wet?
:glasses: :glasses: :glasses:
· Premium Member
I'll be honest, I've never had much luck with the blue tape/caulking method. I'm sure it's me, but, I either wait to long to pull it off or I pull it off too soon and both results are bad. There must be a magical moment when you pull it off and it comes off fine. For now, after 42 years, I'll just keep using my finger......which, can be a nightmare too especially when your finger hits something sharp in the caulk or along the wall and you get sliced.
· Remodel and New Build GC
Generally fingers also........
I've seen some HO's try tapeing.....and the difficulty/problem is ending up with a smooth line tapered out to smooth verse a ridge in the caulk.
(In maybe a couple of strange issues where it is difficult to get an even initial caulk line ...maybe some tape...then pull off excess immediately...and finger it out smooth.)
Did that make sense..??
Most are correct in just leave the tape out of the project. It does work good when using grout chaulk or cement patch chaulk. Use same finger technique when using silicone also, but use laquer thinner on finger. I once had a new log home, I chinked that whole house, it took me two summers, blue tape was my best friend, I would run the whole length then peel tape, by then it would set a bit and you could fix any goobers with a damp foam 1” brush. I Also installed many many marble showers, tubs, vanities, and many many many counter tops. Wish i had a quarter for every tube of chaulk i have squeezed.
Sent from my iPad using Tapatalk
Discussion Starter · #6 ·
Yea I don't think I'll be using that technique again. I waited too long and the caulk start to get a skin on it and when I pulled that tape off I got rippling effect. It work ok where I pulled the tape off a few minutes after finishing but for the time it took to apply the tape the finished product doesn't really look any better than pulling the line with my finger.
I'll need to go back over 90% of the room again tomorrow.
Its a great method when done properly. You have to wipe the crap out of the side of the tape for starters. The caulks ONLY job in this situation is to seal the tape from paint bleeding through.. And you have to pull immediately after painting. So, I usually will run the tape, paint my first coat very close to the edge, but dont caulk it until the second coat, then pull the tape right away. For those who say they never use tape has never had to transition colors on a bullnose edge, like this picture shown. This method also works great for caulking cabinets to the wall with a perfect line, or inside of windows.
Discussion Starter · #13 ·
I actually use this technique on the "inside of the window in the kitchen" right after my first try on on the base and door casing that I let set too long. It really did a nice job, that said I doubt I use it for anything beside something like that but for trim against a wall I'll just use the typical finger swipe as I don't think it's worth the time to tape it all off IMO and YMMV.
Ok, Im confused. Are you caulking to fill cracks, or are you just trying to make a perfect tape line for paint? Cuz its two seperate processes, (usually)
If you are painting a wall and a jamb, you would calk the jamb to the wall, paint one or the other, then, if so desired, run tape and caulk for your perfect line. If you need to keep caulk and paint off the other surface, like a cabinet, or window, or whatever, you could use the tape method to kill two birds with one stone. Tape, caulk, paint, pull, while its wet. Theres still a technique involved though. it has to be taped a certain way. If the tape is too close to the corner, it will mess up the caulking when being pulled. about a 1/16" out is usually good. You still need to wipe as much as you can off the tape edge too.
Also, what video did you watch? Some of them have unnecessary steps. For example, if you are going to caulk over your tape, theres no reason to use expensive frogtape, or even blue tape, unless the surface itself is delicate. Regular old masking tape will work. if you're using frogtape, and the wall isnt textured, you can dampen the edge with a wet rag, and that seals the tape from bleed through, so you dont need to caulk it. It doesnt always work as well though.... Using frogtape and caulk is a waste of money.
Sometimes tape just gets in the way, and sometimes it ranges from "nice to have" to "necessary". One key is to not put the caulk over the tape, in other words it should be there to protect the line, but there should not be any build up. If there is, taking the tape off will be a mess. You use your finger or rag or whatever to smooth the joint, and at that point the edge of the caulk thickness should be virtually zero. Pull up the tape immediately after caulking. If you get a nasty looking edge, then you put the caulk on too thickly over the tape.
It's a long video and I didn't watch it all, but I'd say while the guy does it for a living, it's not what I'd call very professionally done. There are *definitely* times where some of those "fancy caulking tools" (and he laughs). It's just that his situation is not one of them where they're useful. It's also not necessary to use any tape in his situation and it's just going to cause more mess than it's worth. Tape isn't necessary for trim, especially when you're going to paint.
It's more of an issue with paint than caulk. Caulk is too thick to run under the tape much. Still, if you're going to be pushing hard on it, obviously you want to make sure the tape is down well. But like I said, any problems with tape come from putting the tape too close to the caulk line, and/or putting on too thick a bead over the tape. The tape should be at the feathered edge of the caulk line, not where there is any buildup over it.
Discussion Starter · #20 ·
I need to caulk & paint these wall stringers and risers. I'm thinking the tape method work be a good idea to use.
1 - 20 of 34 Posts
