Thanks, I posted the Square D panel model I am using which is made to handle DC current as are the 2-pole, single switch 20amp breakers. My question is the wiring of the breaker's positive and negative terminals to insure that they will trip correctly.
Yeah, as soon as you said Square D I knew you were someone who had done the research (unlike the peanut gallery) and picked QO, or possibly a cheap noob grabbing HOMeline on price. My bet was the first one.
QO breakers don't specify a polarity. Because Square D assumes you'll be using the neutral bar for common; but they can't know if your system is negative or positive common/GND (not to be confused with safety ground). The way you're doing it, given their interleaved bus stab design, polarity on a 2-pole breaker is decided by position. Move it up 1 space, you reverse polarity.
Be VERY careful with that!
Gotta watch that short circuit rating - plenty of batteries out there can put out mad short circuit current. you'll need some proper fusing.
"Mad" eh? You know every consumer grade breaker is rated to interrupt either 10,000 amps or 25,000 amps. Even the lowly QO220.
for example a tesla pack is able to put out over 1500 amps for 3 seconds (0-60 time is 2.4ish) at rated voltage. wonder what it puts out if you short it? I don't want to be near that test.
also thought i'd drop this here:
Cute, but
that's not amps. That's volts. As I often say, DC power turns from Dr. Jekyll to Mr. Hyde somewhere around 60 volts (note the DC rating of QO is 48V, down in the "still well behaved" range). Once DC power turns evil,
it cannot be bargained with. It cannot be reasoned with. It does not know pity, or remorse, or fear, and cannot be stopped until the component it's arcing across is dead.
What you're seeing in those videos is a paltry 10 amps (or 40 amps in one case) at 200-400 volts. The unbelievable arcing you see there is just mid-voltage DC being its Schwarzeneggerian self.
Here's another, turn your sound way down, and wait for it
600 V DC: "I can do this all day!"
OP will be fine at 12-24V. DC is docile at those voltages, and the Square D breaker certainly has the amp interrupt rating.
By the way, notice the one scene where they had a 3-pole breaker and they "snaked" the power through phase 1, looped back through phase 2 and forward through phase 3 (so all 3 interrupts were in series). This is a common tactic, because mid voltage DC is such feisty stuff, it's hard to find (sanely priced) breakers for it. *Proper* DC contactors have either magnetic or pneumatic blowouts, with big arc chutes.
