Can the conduit to a hot tub hookup be used legally for a ground in a 4 wire set up where there is just two lines and a common?
Also, the instructions for the heater and pump call for a 40-50 amp GFCI breaker. There is a three wire 30 amp GFCI breaker already there. The heater pulls 22 amps and the pump pulls 9 amps, shouldn't the 30 amp be big enough and if not the worse that can happen is the breaker will kick, right?
