1 - 11 of 11 Posts
I put custom shelves in my hall closet.
I have a 36" shelf intended for charging about 5 USB things and 4 plugs (iPads, phones, kindle, cameras, etc.)
I want to build an in-wall bank of outlets. Power strips aren't good as the rectifiers and transformers of some devices are oriented in ways that block some of the outlets.
I've seen USB/Recptacle plates but nothing like a large charging bank.
I keep leaning toward a gang box of receptacles and maybe a plate of 5 USB outlets--if those are made. Still searching.
Also, I'm not seeing any that have surge protection.
Any experience or successes would be great.
Thanks as always.
· The Token Engineer
· Wire Chewer
I'd go with the gangbox method myself. I made a power bar a while back for all my computer stuff. One side is UPS protected and the other is not (for bigger things like printer etc).
It makes cable management easier and plenty of room for those big wall warts.
You could do something like this but to fit in the space you have. Maybe built in.
· Banned
What you need is a USB Charging station. Plenty to choose from. http://www.amazon.com/s?ie=UTF8&keywords=usb charging station&page=1&rh=i:aps,k:usb charging station Just need to find one that fits your liking. You could also just use the mini usb plug in transformers, like Apple sends with their iPhones. They only take one outlet. The other choice is to go with the Powermat for the iPhones http://www.duracellpowermat.com/
Camera would have rechargeable batteries, so it would need just to have the charger plugged in when you only need it, then unplugged after done. Keep in mind, that leaving the chargers powered up, creates the "Vampire" affect on your electricity use.
· Banned
Yes it can, plus it prematurely wears out the transformer. I always unplug the charger when I am done, vs. leaving it plugged in all of the time. I have seen some actually short out, that people are lucky that they did not cause a fire.
Discussion Starter · #10 · (Edited)
Thanks. I think I might just skip USB as all the items have a TRU on them like the iPhone plugs.
What about surge protection. Why do power strips have it when they don't know the amps of each device used? Otherwise wouldn't a surge trip the wall's circuit?
· Banned
No. The surge protector is to protect the devices plugged into it. The breaker is there to protect the strip from overload. If that breaker fails, then the circuit breaker on the circuit that the outlets is on, should trip.
1 - 11 of 11 Posts
