1 - 14 of 14 Posts
The upstairs toilet began to leak and I decided to fix it. In my investigation I found a number of problems. Here is what concerns me. The toilet drain Y's off to the vent. The vent appears to be a 3". After removing a section of the floor I found the drain for the 2 sinks share the same line (3") but in the center it Y's off to the main line that is smaller (2"). The Y is pointed to the sinks. This means the sewer water from the toilet must go down the 3 inch pipe and then make a 235 degree turn to get down the smaller drain. Is this right? Do I need to replace the smaller line or can I T into the larger line or reverse the Y?
· Premium Member
That branch on the 3x2 y is probably the toilet vent. Not a drain. You do not reduce pipe sizes downstream on drain lines.
Reactions: wab
Discussion Starter · #12 ·
You are correct. But another question.
After digging further it now appears that the drain for the sinks IS the main drain. Sorry but with everything I have had to do in this house (nothing is the way it's suppose to be) I panic when something doesn't look right. It turns out the 2" is the drain from the bath.
Other question.
A long time ago I was told by a plumber not to sweat copper after it had been in use for a long time. The reason was the hard water caused calcium to build up in the line and if you heated it up it could cause the copper to develop pin holes. Is this true?
· Doing it myself
Other question.
Pictures are worth 1000 words each. Please post more.
· Premium Member
Other question.
Never heard that before. Sounds like he wanted to sell you some new pipe.:whistling2:
1 - 14 of 14 Posts
