Two questions about Uponor:
I read somewhere that it takes Uponor about 30minutes to regain its shape after expanding to the fitting: I waited an hour, and when I pressurized the branch I had water leakage at a fitting.
Now, the PEX isn't FULLY seated on the fitting, but it does envelop all of the ridges. It's now been 48 hours, and I was about to replace the line, but I decided to pressurize it once more, and voila! No leaks?
Would you replace the tube anyways? Or do you think the 1hr just wasn't enough for it to clamp down the first time?
Also, I'm an idiot and left the PEX in my garage for about a month after delivery. It wasn't in direct sunlight, but sun does get in. Some of the PEX I had ordered didn't come in a UV resistant packing: is there something to look for that's telling that PEX has been over-exposed to UV? Or should I just toss it and buy new?
Finally: how crazy do I have to go to prevent UV from exposing the PEX? I've been to some friends houses with unfinished basements, and the sun is coming in thru the basement window exposing the PEX for years (unprotected). Do I need to go nuts covering the PEX with foam insulation? Or should I just cover my basement Windows (drywall won't be going up for a couple months)
