Hi and Thank you,
I am upgrading a 100 amp panel to 200 amp, in doing so the electrical company informed me I need to move the panel to the side of the house making the old panel a sub panel.
What I am curious about is if I can run the leg partially through my attic without having it in conduit. Meaning conduit from the new panel up to the attic, through the attic then back to conduit when it exits at the old panels location. Would save considerable work if I only have to do two vertical conduit runs.
Next question I have is about sequence, I want to tie into the old panel through where the current drop enters. The old panel is seperate from the meter, but I need the meter box above it removed to run the conduit too it.
So do I need two inspections? One for the new drop location and one for the sub-panel since I have to wait to hook up the sub-panel.
Or should I just enter at a different location? Trying to keep from having the power off too long as I reside and it is hot summer months.
Oh, last thing so I understand this correctly, the instructions the electric company gave me has 4/0 wire as the service entrance wire, from what I read this is aluminum wire? 4/0 seems too large for copper and only 200 amps. While on topic of wire size I was going to run 2/0 to the sub-panel in copper which is about 60 ft run, is this correct?
Thanks again for any advice.
Maybe it's of limitted relevance, but a part of me is curious why the POCO says the panel needs to move. Is a new meter socket at a new location part of all this? If so it sounds like there are similarity to my project and you can of course look at my started threads to find a lot of info.
You could use SE type R cable between the 2 panels which would allow you to not use conduit through the attic.
Look at prices of copper vs aluminum before you make up your mind to use copper.
Yes, the new panel is a combo meter box, was told that if I wanted a new drop that the meter had to be moved from the back to the side of the house.
Thank you for the suggestion, Ill look over your project.
I=E/R
2/0 copper is overkill for a 100 amp panel or did you mean #2 copper?
