I’m about to close on a home built in 1971. The popcorn ceiling came back negative for asbestos, but I do plan to scrape all that off and tear out one bathroom, a small portion of wall in the kitchen/living room area, and I need to remove wall paper and do some sanding on some of the walls that look terrible. I’m aware that asbestos is often in joint compound, but obviously I can’t afford to pay an abatement contractor to seal everything up and do all this work.
I will not be living at the property when this work takes place and will be installing all new flooring and zero carpet. My plan was to just open windows and put a box fan in, use a true hepa vac, and clean really good. And of course turn off the HVAC and seal off vents.
That said, I do have a 2 and 6 year old and the two year olds bedroom is the one with awful sheetrock.
Should I be more concerned and take more precautions with my children or is this sufficient?
