Repurposing a room, and I want to add an outlet on a wall that has none. There's a "box" structure, floor to ceiling, about 8" deep and 21" wide, covering the electrical service box. So, the good news is I have very good access from the back (16" x 80" door), and looking right at the wiring including one wire specifically to accept this outlet. The bad news, this is a finished wall and unsure how to mount a box. No stud here, the drywall is applied to a 1"x8 board, so I bored a test hole with a Forstner bit and came up with 1-5/16 wall thickness. I have a nice metal box in my hand with attached flange on one side, but designed to 5/8" mounting depth.
So, what to use? I've seen at the stores a plastic box with a side flange that adjusts in/out for depth by a screw, planning to look at that but suspect at 1-5/16, I'll be out-of-adjustment-range. Also seen "old work boxes" that you insert for the finished side and then to "ears" pop out, basically grabbing the wall in a "pinch" but not actually screwed to the wall
sad
. Alternatively, I visualize attaching a strip of wood (say, 3/4" x 1-1/2") to the side of a box with screws, then screwing that to the backside of the 1"x8" wood. Goofy? Should i be shopping for a box specifically made to mounting depths other that common drywall thicknesses?
By the way, rather close is the door jamb, about 11/16" thick, so if there's a box with an attachment flange of (1-5/16 + 11/16 = 2") from the box's face that's viable.
