I just recently went through my breakers to figure out exactly which breaker is connected to which outlet, light, etc. I'm 99% sure I have found every outlet, light, etc and matched them with a breaker.
I have one breaker that has wires connected leading to somewhere in the house but not sure where. It is labeled pool but I have already figured out which breakers go to all my pool connections.
Is there a way at all to try and find where that line originally ran and is now or am I just SOL short or ripping open all walls and ceilings to just manually follow it?
Reason I'd like to know is depending on where is it I would like to being an electrician in to use that line for a few more outlets outdoors for my Christmas light display. I am pretty maxed out on all usuable outlets right now and I continue to grow my display.
Thanks
Sent from my SM-G960U using Tapatalk
Logically it would be a spare run to some pool j-box and never used. That's be the first place I'd look.
Often there will be a j-box on the outside of the house that allows a home run to be extended u/g to a pool pump and often a light... it may have been elected to have both on the same circuit, which left the spare.
Thanks. Looks like it may be extra. Breaker has been off since I posted and we haven't found anything not working.
