1 - 6 of 6 Posts
There might be a better section to post this.
I have a propane grill, about 15 years old - was a quality grill at the time I bought it. There are two burners - the left side was shooting yellow flames - I inspected the burner, and it was rusted out. I've replaced the burner, but the left side still produces more yellow flame than the right (the 2 burners are in a single piece - a figure 8). When the left side is on high, it makes a significantly louder hiss than the right side.
I disconnected the burner (and I'll probably make the pros shutter at my methodology) I held a match in front of the jets that normally fit into the venturi tubs. Both appear to shoot out equal length flames.
Since it's a new burner, and I've inpected it and there are no spider webs inside, can anybody give me any answers?
· Tileguy
Are the orifices the proper ones? They come for propane and natural gas and they are two different items.:)
How about the dampers? Are they adjusted properly.
About doing what you did with the match...ARE YOU CRAZY?:laughing:
I remember when I first purchased the grill, I had huge flames shooting out of the burners - when I called the retailer, they were chagrinned and came out and swapped out some fittings. They said it had been set up for natural gas.
I assume by orifice, you're referring to the "jets" that fits into the venturi tubes. They each have a pinhole that the gas comes out of. They look the same.
And by dampers, I assume you mean adjustable venturi closings. Neither the new or old venturi tubes have adjustable dampers, though I have attempted to cover parts of those holes and it does seem to make a little difference.
As to the crazy part - that's why women live longer than men.:whistling2:
· Tileguy
Yes the "pinhole" things.
I'm only guessing as I have been down this path a time or two but don't pretend to understand any of it. I do know the orifice variables are just barely detectable to my eye, there isn't much difference in appearance that I could ever see between the propane and the natural gas. I have never seen a gas burner anything (of the outdoor grill type) that didn't have air adjustment dampers.:)
1 - 6 of 6 Posts
