Hvac Pro
Why do you want to know. There are 12-24 different problems with those and you need to understand the fundamentals of refrigeration to understand them.
Administrator
Thats a bigger question then you realize.
Can you n arrow down the question to what your application is.
Wire Chewer
undersized: will run forever and take very long to cool - inefficient
oversized: will not run long enough, stop right away, only to start again shortly after. So lot of on/off cycles. Also inefficient. Will also never give the coil a chance to collect much water, so the humidity control won't be very good.
I'm sure there is more to it too but that's the jist of it.
I learned about the oversizing factor with my 1 ton AC unit I use in a 70 square foot room. :laughing:
