1 - 6 of 6 Posts
We want to put some under cabinet outlets in our kitchen.
That way the area for the backsplash can be uninterrupted.
We found these outlet boxes at Lowe's:
https://www.lowes.com/pd/Hubbell-1-Gang-White-Metal-Interior-New-Work-Old-Work-Standard-Enclosure-Celing-Wall-Electrical-Box/999929904
We certainly aren't committed to these, so if there are other suggestions we would be very interested in hearing them.
The way we use our kitchen the outlets we are actually going to be using are going to be on the other side of the kitchen. These outlets are going to be there primarily because there is code requirement to have them.
I'd be interested in hearing any suggestions for a solution. Or any pros/cons of these boxes.
Thanks.
Licensed electrician
If the recepta*are over 20 inches above the counter they will not count as serving the counter top.
Super Moderator
Oso954 I also changed the "need" to "not". Just so no one will get confused reading your post. :smile:
1 - 6 of 6 Posts
