If there's one comment that I've read in this forum that appears more often than all the rest combined, it's a universal hatred of backstabbed outlets.
So I took a look at the outlets in my house, and, yep, they're backstabbed. (FYI, house was built in 1979, no additions or remodels since, all branch wiring is Cu.)
Should I bother to change all the outlets over to the screw terminals? This would be a rainy day, nothing better to do, a few at a time, long term project.
Also, for whatever reason, all the outlets were installed with the ground pin up, the two blades below it. Does it matter, is there any reason (other than eccentricity) that this was done, should I turn all the outlets "right side up" while I'm un-backstabbing?
Thanks much. I originally started reading the forum to learn about generators, but have learned much more about a wide range of topics.
