1 - 12 of 12 Posts
so I have a corner lot with power lines on both sides, and the feeder running to the house. If possible I'd like to bury the feeder to free up the yard planning, is it feasible? can I do it myself? has anyone tried this?
I don't mind the digging and I'd like to save the tree's around it, so I'd almost rather do it myself so I can be careful with the roots.
Thoughts?
Licensed Electrical Cont.
I assume you mean the overhead drop from the street.
Certainly.
can I do it myself?
Only you can answer this. Depends on your level of experience with electrical work. It is definitely NOT a job for someone inexperienced.
" Euro " electrician
Check with your POCO for the requriement for lateral service requirement and they will tell you the location where they want the meter and the lateral runs will be.
Oh if you going do any expandation or install a above ground or underground pool let them know ahead of the time they will tell you the correct route for it.
As far for do it yourself for burial the lateral run it hard to say unless the local code may say something diffrent so check it out first before you do anything with it.
Merci,
Marc
Learning by Doing
Marc
Marc brings up a good point. Make sure you check with the city and see if you have an utility easement. If you do, make sure you plan to stay 'inside the lines'.
Electrical Contractor
Some power companies won't allow you to do anything ahead of the meter: They are responsible for everything, and that means you will PAY for THEM to do it all, or it ain't getting done! :huh:
I've offered to provide and install such lines for FREE, and been turned down! Since they have the right to demand $$$ for the lines, that's the way it has to be!
So check with the power company, or municipal office as the case may be.
Super Moderator
One utility in MD won't even accept a ditch you dug for the conduit. They do it all or nothing.
Super Moderator
Not PEPCO, BGE.
Customer already had excavating equipment on site. Asked about the route and said I will have a ditch ready for you. Rep said no.
They also charged $1500 to move the drop from back side corner to back back corner, less than 1'. Said charge covered new triplex. They used the same triplex. All they did was move anchor.
1 - 12 of 12 Posts
