Hello.
I need to run approx 90-100 ft 6 ga wire. Ideally I would like to use only one type of wire (to avoid using several boxes). Here's what makes it hard.
First 20 ft - wire goes between raised ceiling in a basement and 1st level floor (approx 1.5 ft above ground level).
Second 20 ft - in a crawl space (it is dry there, it is also approx 1.5 ft above ground level)
Third 20 ft - attached to external wall (wet location) - also above the ground. I think I would run it in Sch 80 conduit.
Forth 20 ft - inside the attached garage 10 ft+ above the floor
the last few feet - behind a drywall.
Is there a wire type / cable suitable to use in those conditions? I thought about copper SER (it can be used indoor and outdoor above the ground, not sure if it can be ran in conduit), but I cannot find it in that gauge. Are there any other options?
Thanks,
J.
A "Handy Husband"
SER or UF.
Reactions: Jack_Zzz
Discussion Starter #4
can you run PVC all the way?
Rigid PVC may be not an option especially for initial 40 ft. The wires would have to go across floor joists (I hope I use a right term) which have pre-drilled holes. Unfortunately, the holes are not aligned and the wire will have to zig-zag a bit.
BUT, I think that ENT should do the trick.
