There is a mid century house. Appears to have two conductor ungrounded wiring. The original outlets are two prong unpolarized.
On the spectrum of: Code compliant...might work but better not...OMG NO!!! can you install a three prong outlet to a two conductor wire by jumping the neutral to the ground? I ask because there is a modern GFCI outlet in the kitchen but no indication that new wire was run through the open basement. So either the ground lug is open, or it's tied to the neutral. I haven't checked which.
And that's only a question because the owner wants to put in some more three prong outlets. So ground lug to neutral, doable or no?
