Hello all,
I recently had two outlets installed on a new breaker, working fine. i have a smarthome remote control switch keypad which, needing a power feed, was connected to the end of the line. now the outlets don't work, but the switch does. it's on a 15A breaker. Any ideas? HELP!
wiring
The neutral wire out of the outlet was connected into a cluster, so the neutral wire from the switch was clumped into that, and the power line from the terminal outlet was fed out from the back of the outlet and connected to the switch. can you tell me how it is supposed to be wired if this is wrong? because BOTH outlets on the circuit now do not work, not just the last one.
