At least one ground rod is required by code. In order to install only one ground rod, you must be able to prove that its resistance to ground is less than 25 ohms. If you cannot prove this, you need to install a second rod. Most people install two rods from the get-go because proving <25 Ohms is more difficult and more expensive than installing the second rod.
