" An electrical snake wire".... gezz I hate snakes. Now I'll never want to touch my two Greenlee fish tapes again. :smile:
Lot of people may not think about this, but KT as long as was installed properly and has not been tapped on to improperly or mutilated, was a really safe wiring system in its day.
With the KT conductors OC protection being most times the old Type S screw- in glass top fuses, any overcurrent situations were covered well and dependable, with the Type S fuse's melting solder links. Short to ground/ fault protection ? Hmmm. not so much.
I re-wired a lot of the early 1900's houses back in the day that had KT. And not one of them was because of a electrical fire caused from the KT though. And IMO, KT was good in its day because the KT conductors never touched wood.
Unlike the two more modern homes that I did service work on where the abuse of the electrical cable caused a fire. In one home, someone pulled a Type SE for a range cable 50 ft, across an attic. When it came over the last ceiling joist, apparently it was a inch too short for the installer.
So the wire puller put all their weight on as it came down through the top plates and then stapled it tight. The cable was as tight as a fiddle string across all the attic joists.
So over time, the sharp edge of the top of the joist at the wall's top plate from the homes slight movement over the passed 40 years, cut in to the cable. While exposing some of the hot copper strands to the wrapped neutral stranded conductors in the SE cable, making them arc and ignition followed.
And another electrical fire I was called to, was where a kitchen soffit had the 7 in. recess can lights installed in it. And one of the can lights had its 3/8" Romex cable connector screws on the cable so TIGHT where it entered the RC light's J-Box, it finally cut through the cables conductors and sparked, setting the soffit space on fire.
Neither event would have happened...with KT wiring IMO. But we all know that we have better wiring cables in our homes now. As long as they do not get the abuse, as the ones in my post here had done to them. JMO.
