I've done it now!
I had a leak in my bath tub faucet(an old delta). I tried removing the collar nut, or whatever it's called, it was very difficult to remove and now i've twisted the valve body. I did get the nut off, replaced springs, rings/washers, etc. Then I put it all back together. With fingers crossed, I turned the water back on. Now it leaks from the back.
Is it shot? Is it possible to bend it back into place and solder any cracks that I may find? I'm not experienced with installing new piping, torch and solder....I don't look forward to cutting the pipes and re-piping. But if that's what I have to do, that's what I have to do.
Also, will I have to replace everything, valve body and faucet?
I can't cut the water back on until I have it repaired, because the shutoff valves aren't functioning properly. I'm going to have to take the day off tomorrow to fix this mess. So, any advice will be most appreciated!...the wife is not happy.
