1 - 19 of 19 Posts
Greetings!
I have a bathtub/shower drain on the 2nd floor of my house that is clogged (only drain with a problem in the whole house). I have replaced the metal overflow, drain and trap with PVC but still no luck. The remaining cast iron metal pipe is horizontal for about a foot or two, and then goes into a tee. I have pushed a 25 foot snake through this pipe but still no flow. The part of the tee that goes down meets up with other drain pipes less than 25 feet from where I am snaking. Also my wife said she thinks she heard me snaking loudest in a room above the bathroom. I can think of only 2 possible situations at this point.
1. my clog is below the tee and my snake is going upwards at the tee.
2. my clog is in the vent and my snake is going downwards.
If my clog is below the tee how do I make my snake go downwards? Is it possible that a clogged vent would not let the tub drain? I have a big cast iron clean out in the basement but the other pipes meet up with the pipe that I snaked before the clean out.
Thanks for your help everyone.
Premium Member
Sounds like your going up the vent instead of down- happens sometimes.
I usually don't have any cutting heads on my smaller cables. This allows me to put a small 45 degree bend in the cable. When inserting the cable, orientate the bend to the tee. It should the drop down the tee to the blockage. There's a good chance the obstruction is right there and forcing the cable to go up the too versus down.
Reactions: plummen
Do you mean you cut off the end of the snake that opens up a little (about the size of a thumb)?
Thanks
try a couple times to see if you can get it to go down the other thing is does the vent go straight up and out the roof if so you can run snake down from there i have had to do that before
Doing it myself
The only thing I see missing from your original post is where you pulled the stopper for the tub and yanked a bunch of hair out of the lower shoe.
:whistling2::wink:
If you did already do that, you need a drop head, as suggested above, and possibly a different size cable depending on what you're using.
No hair, just rust. I'm using a 25 foot long 1/4 inch snake attached to my drill. Last night I got it to go downwards by bending the head a little. It drains but its slow. No slime on the snake, just rust. I guess I just need to do it a few more times.
Premium Member
Please clarify- Did you replace all of the waste and overflow, including the drain shoe and ptrap?
Premium Member
yes. All that is left from the original is the tub and a cast iron pipe sticking out horizontally from the wall/ceiling.
If you have a trip lever tub drain, make sure the linkage is adjusted properly
retired elect/hvac/plumb
Thanks
Thats what I do,then bend a 45 degree bend into the end of the cable :)
Premium Member
Same here. Nobody at our shop has heads on their small cables
We don't have small cables at our shop because some @#$^#^# keeps using them to snake mainlines.
:whistling2::whistling2::wallbash::icon_rolleyes:
Now thats funny! :laughing:
Heh. I don't even buy the tools and it ticks me right off every time one of them comes back in a huge knot.
It happens,I had 1 of my guys rip a bucket right off the back of one of my backhoes years ago just because he was too lazy to replace a cotter pin,cost me $2000.00 plus to fix for a $1000.00 job and he couldnt understand why I wanted to drop the bucket on his head! :censored::censored::censored::laughing:
Doing it myself
I bet your guys learn after they mess up.
:laughing:
So far 3 small cables knotted from cleaning mainlines, and he still does it.
That same guy left his old truck and boat sitting at my house for close to a year after that episode,I came really close to launching his truck and boat/trailer into the misouri river after that episode! :furious:
I was just gonna tell him "youre not gonna blame that on me are ya?
Thats the same line he layed on me after destroying my tractor! :laughing::laughing:
1 - 19 of 19 Posts
