Hey guys, great forum :thumbsup:
I've been battling low airflow to the kitchen for the past 18 months since we moved in (3050 sq ft 2 story). I'll have to get the blower details later, but it's a Carrier installed about 8 years ago. It's a 2 story, and the kitchen run is the longest of the bunch (I'll have to get pictures later) with 8-inch flexible from the blower. I'd estimate that the horizontal run in the attic is about 45 feet, which then wyes into 2 6-in ducts that drop down 10 feet into some kind of sub floor register box, then on down to the kitchen. I had a guy out yesterday who recommended replacing a large section of the 8-inch with 12-inch from the blower, then using a 12-8 reducer about 25 feet downstream. Basically saying it's way undersized for feeding such a long run. Is there a general rule of thumb stating where your step-downs should be in relation to X feet away from the blower, depending on the CFM? I did add an inline booster fan to the 8-inch before the wye and that helped a tad bit. He also recommended cutting off some excess of the 6-in ducts to remove the "scrunching" and rounding out any curves. Also to enlarge the access hole to the subfloor registers and check for any leaks. Luckily these are accessible because part of the attic is a walk-in room with these ducts in plain view.
The outside unit is a 20 year old 4-ton (upstairs 3-ton) and the rest of the house still stays cool. Last year in the Houston summer our bill was in the low 400s, however we were paying about 15c / kwh (10.8 c this year
), so really that's not bad considering how blasted hot it gets here. Sorry for the long :whistling2: post, thanks for any advice.
