I have been wanting to replace my 23 year old home thermostat with one that is wifi enabled. So I purchased a Honeywell RTH6580WF. I have a central heating unit converted to propane, with A/C. When checking my current wiring for compatibility, I found that while a C terminal is required on the new thermostat, my current thermostat does not utilize it.
According to Honeywell folks, a work-around is to move the G terminal at the furnace side to C terminal. When I checked on that, I noticed that the C terminal at the furnace is already being utilized along with Y terminal, on another wire run. According to my furnace literature, that wire run “goes to CC” (compressor contactor) which I presume is for the A/C.
While investigating all this, I noticed that the wire bundle from the furnace to thermostat has an un-used wire (for reference, color blue). I discussed the possibility with Honeywell of leaving the furnace G wire alone, and hooking up the blue wire to C terminals at furnace and thermostat, thus obviating the need to move the furnace G wire. Since the C terminal would be shared the Honeywell folks would not commit to a definite answer (at the time I did not know the destination of the “CC” wire run).
So, my question: Will it be OK to hook up the un-used blue wire at the furnace to the shared C terminal and to the C terminal at thermostat? I can provide photos if that will help.
