I took wallpaper off bathroom wall and it pulled some spots off the drywall. wetting it just made it just made it bubble. so now I dont know how to fix it. I wanting to paint the wall. do I need to mud over all of it or is there a certain kind of paint.
Thanks
· Premium Member
Sherry if you do a search you will find at least 30 threads on this type of topic.
Remove as much loose paper, bubbles, loose gypsum that you can. Prime the damaged spots with a good drywall primer (Guardz). You have to first prime the damage or when you apply mud, those spots will bubble up. After a day or two of drying time, apply some joint compound, let dry, sand, and apply a second coat or even a third if necessary. Sand, remove dust, and prime the spots again. Then you can top coat with your choice of paint.
Remove as much loose paper, bubbles, loose gypsum that you can. Prime the damaged spots with a good drywall primer (Guardz). You have to first prime the damage or when you apply mud, those spots will bubble up. After a day or two of drying time, apply some joint compound, let dry, sand, and apply a second coat or even a third if necessary. Sand, remove dust, and prime the spots again. Then you can top coat with your choice of paint.[/quote
Gymschu thanks for the help I guess this was not going to be as easy as I thought. but hopefully the outcome is going to be worth it :)
