Hey guy's
Trying to work something out, I hope this is the right section...
So: Concerning a:
Concrete floored Garage (epoxy coated), to asphalt driveway
The pictures will tell the tale.
I'm trying to figure out how to put together a slight ramp to join the garage step to the driveway, I wheel things in and out of the garage, so I'd like a small ramp like 2 or 3 inches, like the size of a corner triangle bead.
So, I'd like to bolt down have some hard rubber step guards (A) into the concrete (the full width of the door)
I had put some gripper strips (B) they were self adhesive, these went over the EPOXY coating which also covers the step.
The driveway is Asphalt, (C) I had used a coating a few years ago to designate a walkway
I had also put in a rebar (D) which did work well.
However went winter set it, I found the snow shovel started breaking things up, which is another thing I need it to be able to endure snow
I was "thinking"
1> Bury the rebar in deeper
2> Get some kinda triangle cornering over that
3> Use a hot liquid Asphalt to cover the area (F) the full widht of the door
4> I would drill some 2x4's t contain the form while it sets
has to withstand winter, people walking in and out and my car driving in and out occasionally
txs
So: Concerning a:
I was "thinking"
txs
