Hi,
I have noticed that my TrueSteam humidifier has started doing two things that it was not doing in the first 3 years of its use, specifically:
- when humidifying, the hot water is slowly but constantly leaking through the drain pipe. I believe in the past it was only draining the tank once in a while
- again, when humidifying the water drips (like a drop a minute) from the red latch at the bottom
The unit has been installed by a contractor but I know it quite well and do not mind fixing it. So I am looking for a suggestion - is it by any chance a known issue? I was thinking that it's got to be the water sensor problem (although no errors are shown by the unit) or the solenoid valve itself.
Thanks!
Thanks!
