I have a 20 yo troy bilt pony tiller. About 10 years ago, I had the engine go bad during the garden season. I was in a hurry and replaced it with a HF predator engine which worked fine but left me without a reverse. I scrapped the old engine and don't remember much other than it was a briggs with 2 output shafts.
As I am aging, I find myself needing/missing the reverse on this. Has anyone replaced the two shaft engine on one of these, and can get me a model number on a replacement engine? I do remember that the conversion to the HF engine was easy, I think I just needed a bushing and the rest was just bolting up.
Are you sure that the original engine was a Briggs? Or was it a Tecumseh? For tiller and snowblower applications, Tecumseh offered engines with counter rotating camshafts, and mounted a pulley on that as well as the crankshaft. This way, on your tiller for example, all that was needed was belt and tensioner on each pulley, driving it forward from the crankshaft and rearward from the camshaft. The obvious benefit for manufacturers at that time was that they did not need to incorporate a reverse in the transmission because it could be accommodated by simply adding that second belt and tensioner. The downside today though is that, as far as I know, Tecumseh was the only manufacturer to produce this style engine and they are no longer in business.
At Dexter said about the Tecumseh engines is what I have found also. You may want to look at a new Troy built like yours and see how they handle the forward reverse. I'm guessing they have to put a transmission of some kind in but maybe another way to do it. Certainly worth looking at a new one to see what they are doing.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
