I've tried booting up my AC unit for the first time this spring and it's not turning on.
The furnace fan turns on but the AC doesnt budge. I checked the obvious things and all looks good - thermostat appears to be wired correctly, the drain line is not clogged, fan isnt seized, breaker isn't tripped.
I used a voltage tester and there doesnt seem to be any power feeding the unit. However, the thermostat wire seems to set off my tester so it has power running through it.
Any idea on what could be the problem??
