1 - 2 of 2 Posts
Hey guys, was hoping you can help me.
To start my house has an electric furnace hot air with a York Air Conditioning system, two zones (upstairs and downstairs), and in each zone I have one motorized damper. The damper motors are Invensys (model 0483H0004FA00) and the control panel is a Robertshaw SlimZone Classic. My current problem is that the two dampers damper motors stay close all the time when the LEDs (LED #1 and LED #2) on the control are green (documentation say Damper Open). The LED #12 is flashing too (functioning properly). All seem to work except the dampers staying closed allways.
Have you a solution for me.
Thanks in advance
Administrator
Use a volt meter and see if they are getting 24 volts. If they are its time to replace them.
If not, the zone panel could be worn out.
1 - 2 of 2 Posts
