Need some basic guidance troubleshooting a heat-pump. Noticed that the temperature rise was only only 1-2 degrees, on mild days, and that the system was having to engage the resistance strips to produce any real heat, even on warm-ish days. Being the original owner, I know its performance characteristics (will usually not require resistance heat until -15C), whereas suddenly, it couldn't keep the house warm at 0C / 32F.
Here’s some possibly useful information:
Breakers all checked out good. None had shut down.
Outdoor compressor starts and runs normally.
Indoor furnace fan is also working normally.
Filter is new, and air-flow is unobstructed.
When operating in heat-mode, the large, insulated, copper pipe connecting the exterior heat-pump to the interior furnace/air-exchange is as-expected, hot to touch. This would seem to indicate that the compressor is doing its job and getting adequate heat from outside to bring inside for air-exchange.
Unfortunately, heat pump is mounted on the roof which is very difficult to get to right now. Thus I'm simply running on resistance heating and have locked out the heat-pump, until spring. Or until a better idea comes along.
Given this limited information, is it possible to assess the likelihood that the problem is low refrigerant, a bad reversing valve, defrosting, or other electronics?
Brand of the unit is “Aire-Flo” which I believe is a builder brand of Lennox. Unit is 9.5 years old. Its needed a newblower motors, and a heat sequencer, which isn’t bad for 9.5 years.
Would running it in cooling mode at this point add to the diagnostics? Current temperature is 8 Celcius / 46 Fahrenheit.
Thanks for any suggestions.
