I have 1 by 6 trim that goes around the perimeter of the master bathroom. I'm in the finishing stages right now and want to add a cap molding, which is basically shelf-edge that I purchased and stained. The trouble is there are a few spots where the 1 by 6 trim terminates into vertical window trim or the 5 quarter inch trim that borders the shower and they stand proud of the perimeter trim. So when I go to put the cap molding on and try to miter it with the standard 45 degree angle it doesn't work. As you can see from the photos that I have attached if you do a 45 then the bottom part of the Shelf Edge is not flush with the end of the trim and is held back which I think looks horrible.
On a couple of spots I was able to do a 45 and get it to overlap the vertical piece but they're ends up being a small sliver that needs to be filled in order to do the return. I tried to do a straight cut and then cut off the half round to a 22.5 degree bevel like you would do on shoe molding but it just doesn't look right because it's still not terminating into anything. The straight cut looks the best even though you're seeing the side of the profile but I know finish carpenters look down upon that type of thing and believe you should terminate everything with a return. So I'm not sure how to fix this. I would love some suggestions. Please check out the photos for clarification.
