You need something more than paint stirrers....
use 1/2" plywood or bigger or 1x stock
You mean to get the screws to countersink? Or just as a matter of general good practice so the patch is stable and secure?You need something more than paint stirrers....
Both.You mean to get the screws to countersink? Or just as a matter of general good practice so the patch is stable and secure?
What do you mean by a "screw gun"? A "drywall screw gun" will always have a Phillips #2 bit in it and will always drive the screws to the depth you set it at.Simpler is nice...but not necessary. Their function is to put the screw in TO the correct depth but not PAST it. Philips bit in a screw gun will do as well with putting the screw in if you are careful. Ron. PS you can ALSO do it by putting strips of 1/2" Sheetrock as the backer, will screw in and dimple up just fine.
You're saying that you can use pieces of drywall instead of wood here?you can ALSO do it by putting strips of 1/2" Sheetrock as the backer, will screw in and dimple up just fine.
So your saying if you overlay drywall such as in soundproofing you don't need to hit the studs with the second sheet just screw it to the first sheet?It has taken me more time to type here than it would have to have fixed all of the holes. Nestor substitute drill/driver for the words screw gun. And I know exactly how they all work. A drywall gun or a dimples would be nice...but is NOT necessary for a job this size.
Tool seeker, I say the screw will hold in two pieces of drywall bed because I just DID it a couple of weeks back because that is all that there is available.
And to all, the guy has a hole in his drywall. You get something that will fit THROUGH the hole and is thick enough not to split and a put a quarter of the theists of the hole and screw through the outside drywall and the inside support. Do the same at the BOTtom part of the hole. Cut your patch to fit INSIDE the hole, screw it to the supports, done and done. ALL the op needs are thicker pieces in back that won't just split. Ron
Don't forget this is a DIY site. Most on here don't hang drywall a lot. I would venture to guess some don't know for sure the proper depth for the screws. A DeWalt dimpler is what $5 then you don't have to guess if it's deep enough or too deep.Kind of a funny thread. Countersink the drywall? lol Drywall dimplers required? c'mon.
Throw out the paint stirrers. Use real wood furring. If you can't get the screws in correctly with just a regular driver/drill bit, then you shouldn't be allowed to use one. Of course the dimpler bit helps if you have many screws to drive. Or use a california patch liek throrope suggested.
Well, not just DIYers. My carpenter insists on using his impact driver to hang drywall. Literally every one of his screws is overdriven, so that it countersinks too low and damages the drywall.Don't forget this is a DIY site. Most on here don't hang drywall a lot. I would venture to guess some don't know for sure the proper depth for the screws. A DeWalt dimpler is what $5 then you don't have to guess if it's deep enough or too deep.
