Now that I can remove the J channels from around my windows, I need some Ideas how to most efficient and good looking trim.
The first window is a 6ox5o and starts at the brick, the 2nd window is a 5ox5o and has one 2x4 between the first one and it, the 3rd is a 6ox5o and has a 3x4 between it and the previous and the last hits the brick wall. So 3 windows with a 2x4 separator.
If I remove the J channel I get approx 3-1/2" between the brick and window 1 frame, approx 3-1/2" between 1 and 2 and the same for 2 and 3 and 4 and the brick, About the sam on the bottem and top.I have several ideas,
1. Use rigid foam to cover the nailing fins from casing to casing then cover the foam with a piece of vinyl. Caulk the vinyl to the window vinal.
2. Fill the gap with wood and cover with vinyl, caulk,
3. Fill with lo expansion foam and cover with vinyl, caulk.
4. Fill with fiberglass insulation and cover with vinyl, caulk.
The inside I will stuff iunsulation beside the frame and start a piece of wallboard at the seam for the surround, that would meet with the wall - wallboard and get trim wood or picture frame, top, sides and the bottem gets a 6" shelf.
opinions on thers or any othere ideas,
thanks
thanks
