Greetings...
I’m about to paint ALL of the interior in my (new to me) home of 2300 sf. Crown molding, 10’ ceilings. I’m a little confused about a couple of things. All of the trim is in good shape and currently painted white, semi-gloss latex. I will be spraying it.
1) Is sanding necessary in this case? If so, will a quick pass with 120 grit get it?
2) What is the correct procedure...clean with tsp first? But that leaves a residue which has to also be cleaned off...so use a tsp substitute? Then sand, then vacuum then wipe with a damp rag? Seems overkill but will do if necessary as I am pretty fussy.
3) I’m painting kitchen cabinets the same color as the trim, a warm white. I’m nervous about painting all of the trim and the cabinets white with an alkyd because of the potential yellowing. That’s a tremendous amount of labor that could be wasted. Does anybody use a semi-gloss latex for trim and/or cabinets? I understand the pros and cons of alkyds but just wondering how much I’m giving up by going latex. My cabinets won’t get much abuse so I’m not terribly worried about durability. I insisted on a BM latex on my last cabinets that were sprayed by a pro and they looked awesome. Took it to my friends at the local BM store and they agreed even though they pushed my real hard to use the Advance.
Thanks for your opinions.
