Hi,
This is my first post to this forum, but I've been lurking here and on the contractor one for a while, and I'd like to preface my question with a really sincere, "thank you," to the community here in general. That being said, here goes:
My wife and I bought our two story fiber cement siding house three years ago, we live in central Texas, and I decided to paint the house myself. I want to note that the house is still in pretty good shape, so it's not like I'm doing intensive repairs here. After too much research and trials to figure out what worked, what didn't, and what wasn't worth doing, I got the siding painted. When I started looking at the trim I noticed that some other problems we had encountered stemmed from what can only be considered poor construction practices. I want to replace a bunch of it because there are really awful looking joints that have absorbed water, but I realized that replacing the siding correctly may involve some big decisions.
In the images below, the first depicts the way my trim has been installed by the builder: they ran the fiber cement siding to the edge of the house... sometimes - the length which they extend under the trim varies wildly from about a half an inch to about 5 inches. Capped on top of that, they fastened on the trim. The siding underneath hasn't ever been painted or anything.
The way all documentation for fiber cement siding I can find says the trim should have been installed is the second way, which involves cutting the siding to length and butting the trim up against it.
My dilemma is this: if I replace the trim that needs it, should I replace it with the same (possibly wrong) convention the builders used, or should I attempt to correct that? I have I think 160' of trim on the house, some of which is 16' in the air, and this is a one man operation. If I replace it the second way, that means cutting the existing siding by getting the necessary, somewhat expensive tools, somehow getting some of it way off the ground to install, and rethinking some architectural geometry also really high up in the air. I''m really not interested in doing that myself.
If I just replace the material with the same method, I'll save time, but could potentially be leading to bigger problems in the future as that unfinished siding under the trim rots as water makes its way under it, not to mention some of that water getting around the protective barrier. Being in central Texas, we don't get a lot of rain, so I don't know that it's that big a deal that they installed it that way, and it has to have passed inspection at some point, so surely it's not that bad.
If anyone has any insight into this situation, I'd really like to know. I'm also not sure what nails I should attach the trim with if I go the second way. Some of those will surely go through the fiber cement where it extends further under the trim, and I don't feel like a trim nailer will work for that, meaning I'd need to rent or drop the money on a bigger nailer, because I'm not dragging siding 16' up in the air so I can balance it and drill holes for the nails as recommended to avoid cracking the fiber cement.
I'll attach actual photos as well, but I'm at a loss here, so any guidance is greatly appreciated.
Thanks!
Thanks!
