trim bath surround to fit
832 Views 8 Replies 5 Participants Last post by  jlhaslip
so finished the drywall......... Have to now install the acrylic tub surround- The surround is 60" wide- my opening is about 59" - I am hoping it's not exactly 60 wide- If I need to trim the surround- what is the best way? put circular saw blade on reverse??? The manufacturers site says it can be cut (has to have holes cut anyway for plumbing)- thoughts??
1 - 9 of 9 Posts
What is the material? Is it a flat one?
Will the cut edge be hidden?
Acrylic I think. Cut edge would be hidden
If you have an oscillating multi tool---that will work--the 'half moon' blade is dandy if you have one.
A fine blade in a circular saw might be safe--might--I've done that--but it's a big risk.
Jig saw would do the job with a fine blade.
#1, I'd never install a glued up enclosure, way to thin and looks cheap.
A nail on one is at least three times as thick.
A plywood blade on a cirular saw put on backwards will cut it without shattering it.
Usually the tub should be installed before the drywall.
is it glue up or screw up walls?
For some reason, I failed to notice the "glued on" part.
Carry on.
1 - 9 of 9 Posts
