1 - 2 of 2 Posts
First post hope I put it in the correct place. I have a raised ranch with shake shingles. I would like to remove shingles around windows and box around windows using Azek. I was thinking of using 5/4x4 on the sides and bottom with 5/4x6 on top with a trim moulding attached to it. The few questions I have are because I'm using different size boards I can't 45 cut all corners. My choices would be to cut the bottom two at 45 and be square on top or cut my piece on bottom 7 inches longer and drop the sides down onto it,or is better to make the sides 3-1/2 longer with the bottom piece being the same width of window.
Now for flashing. Should I flash on top of the window or on top of the 5/4x6 Azek or both.
1 - 2 of 2 Posts
