1 - 8 of 8 Posts
· Usually Confused
You could build up the stringer with a piece of wood -tall enough to make the trim meet and slightly narrower than the thickness of the stringer to give a stepped look. Use something nicer than regular dimensional lumber. Or wait until something closer to a carpenter chimes in.
· Retired Moderator
This may be a little heavy but if it were mine or I were called to fix that, I would first of all not use the base on top of the stringer, I would go with a base cap. I would cut the floor back and use a landing tread at the landing and continue it around and back into that pony wall. I would let the base cap and stringer die under the landing tread.
If you wanted to do it where it would really look good, do as I stated and also install a post and rail there to keep someone from stepping off that first step.
· Jello Wrangler
Bingo! Here's your answer OP.
^^and that's the right way to do it^^
1 - 8 of 8 Posts
