1 - 13 of 13 Posts
Excuse me for my stupid question:
I'm adding a hot/cold spigot to the house to replace a failing standard cold spigot. Since I'm plumbing the entire basement as well, I ordered a Spigot with PEX connectors, and I soldered on a ball-valve PEX stop onto the copper water supply.
I have abou 8inches between the spigot and shutoff valve: I already installed the spigot, and siliconed it as well.
Last night I decided to connect the PEX, and being the first time I've ever used it, ran into an issue: the PEX doesn't have enough flex to connect to the fixture to the supply.
Are there any tricks to this? Or do I need to cut the spigot out, and connect that way?
Not an answer but my inquiring mind needs to know why a stop valve is needed at that location.
Maybe I used the wrong term? It's a 1/4 turn shut off valve.
I live where it can freeze, so most spigots have shut offs inside the house... But it's also useful in some instances to keep people from stealing water. (I came home in my old home to find a contractor hooked up to my water supply fixing the cement sidewalks in the neighborhood without permission.... And water isn't cheap over here)
Discussion Starter · #10 ·
It's a straight shot, so the PVC wouldn't work. But I think since I only have 8" of length getting enough bend to get onto the nipple is difficult.
I'd rather not try and remove the spigot so I'll go with some heat.
Discussion Starter · #12 ·
you should be able to get that no problem, even if you kink the pex by mistake, just heat it up and it will go back to original shape with no weakening of the pex..
I'll give it another go tomorrow night after I pick up a heat gun. Its located between joists and framing, so getting hands in there is tricky, let alone trying to work against the clock (PEX expansion fitting, so you only have a few seconds to work with)
1 - 13 of 13 Posts
