I'm retrofitting an on-demand propane hot water heater in a situation where the gas line comes in at a height such that it's a horizontal run to the regulator and then a short 90 degree turn to the heater connection. Regulator has to be installed horizontally for lock-up to function properly. I need a trap upstream of the regulator, and I'm wondering about how to properly install a trap in a horizontal line, if that is even possible. Do I need to put a short vertical jog in the line just to install the trap and then on to the regulator? Seems like a horizontal tee wouldn't be that effective, but maybe ok if within (how much?) xxx of the regulator?
Thanks for any insights.
