Hi,
I have a broken transom window. I am wondering what is the best repair option I have? It's double paned and the inside pane didn't break. I'm not sure if this window was sealed (hermetically?) or not or had argon gas for insulation prior? Is it enough to pop out the trim, cut out the glazing and just replace the glass? Or would a complete new transom window unit be required for a proper fix? If replacing the unit, how would I remove it? Thanks for any insights!
